XY8 coaxial quad airframe kits, factory seconds, $475 each
A batch of frame plates came from the production shop with slight fraying around the bottom sides of the cut edges. They were sent back and in an attempt to clean them up they actually made them look worse, at least to me. My standard for carbon fiber cut edges is a clean machined edge with square corners and no evidence of fraying.
I'm putting five frame kits up for sale with frame plates that came from this batch. The lower edges of the cut-outs have some evidence of fraying and edges that have been lightly filed and sanded. These edges aren't visible when the parts are assembled but I won't sell these at full price as production parts.
The remaining parts of each kit are all production, first quality parts.
Please specify if you'd like the arms for up to 12", 14" or 16" arms. There is also a collapsible arm option (add $75) which is good for up to 12" or 14" props depending on the cut length of the boom material.
The XY-8 frame was designed to put the arms/motors/props out to the side so that they won't drop into view of your camera when filming/shooting during maneuvering flight. It flies as well or better than any of the other designs available. The minimal cross section of the landing gear makes it handle wind with ease and the coaxial motor layout makes even descending flight more controlled. The frame design has been flown with Mikrokopter, Hoverfly, DJI WKM, and will soon fly with the new Xaircraft SuperX system. There are mounting holes for MK, Hoverfly, and KK2 and plenty of room for mounting any other system you might like to try.
The oversize frame plates allow the arms to be shorter and thereby more resistant to twist and bending using lighter components.
The motor mounts will accommodate most of the commonly used Tiger motors including the MT2814, MT4008, MT3515, and MN4012. The smaller MT2216 motors can be used but require two additional holes to be drilled in each mount.
Plenty of spares are available and production will continue into the future.
There is room for up to four battery packs if so desired and there are holes to which Droidworx landing gear or PhotoHigher mounts can be attached with the right bracketry.
Here's a photo of a recently completed build...
A variety of configurations can be found here;
http://aerdro.com/?product=xy-8-frame-kit
Full kits will be ready for shipping by the end of October. Email me about build services at [email protected].
