If you or anyone is going to get an X8 make sure it is Bart's XY8.  it has so many advantages over a typical X8 it's really not even funny.
You get easier orientation, no props in the F.O.V., packs up easier, with his custom camera mount you can actually point the camera upward without seeing props!, you can use it as a quad or octo, has good redundancy AND you would be supporting a small business started by the guy who brings us this forum.
As for the dual operator gimbal, I will let you know how it works out. Certainly not having a coaxial is probably ideal for the 360 setups. BUT, in my limited experience, the camera is usually pointed down a bit anyways and as long as you arent doing 360 pans while pitching forward more than 10-20 deg. you are probably fine. This is the one area of question I have for the X8 config. But certainly as a single operator setup (without a 360 gimbal) it is the bees knees.
