Markeaye
Markeaye
Hello all, I have a problem on a new quad build that's driving me nuts. First let me give you the build specs so we can be on the same page.
Frame: HK X650F 550mm fiberglass and alum
Motors: Banggood A4008 380kv high torque pankake motors.
Props: APC style 11x4.5, 12x3.8, and 13x8, have tried all three
ESC: 30amp Simon K
Controller: APM 2.6 vers. 3.1.5 with Ublox Neo 6m GPS/compass, and 3dr telem
BATT: 5000mah 3s lipo
Radio Turnigy 9x with Turnigy 9x8c v2 receiver
Weight: about 3 1/2 to 4 lbs
I tried to be as careful as possible with this build, and tried to do everything by the book. All the programming was done with Mission Planner. All indications appear to be good, 3d sattilite lock, Mavlink hooks in fine, calibrated esc's with the radio, and has a smooth linear throttle, all props turning in the proper direction, and not mounted upside down.
The problem: At full throttle it won't lift off. Pitch it forward or back and it will tip over. Yaw left or right and I get a strong twist. It looks like it's taking out the spring in the carpet, but just won't come up off the floor. As you can see from my specs, I have tried three different kind of props, with no change, allthough the smaller ones won't tip it over with pitch control.
I had originaly ordered 620kv motors, but the supplier shipped 380kv's in error. I'm still fighting with them over this, but getting those in charge of the proverbial slow boat from China takes so long it's has gone beyond stupid.
I really think I'm just not getting the thrust form the slower motors, and the 620 kv's I wanted in the first place would resolve the problem. If anybody can suggest an alternative answer, I would appreciate it.
Help, if you can, Markeaye
ESC: 30amp Simon K
