x1 and x2 setting for pich and roll
paktazh
has any one updated to the new firmware 3.12 it does not allow u the change the roll to x2 only x1 unlike the previous one does any one know how to i just want set my gain so i can adjust the pitch and roll during flight i could only to change both to x1 but no x2
a4u2env
Check the "Intelligent Orientation Control" on the Advanced --> IOC tab within your Naza assistant software and look at the check box. Make sure that box is unchecked. I have found that that will lock up the X2 and remove the X2 option from anywhere else.
CrashMaster posted a couple of weeks ago that he had trouble with gimbal settings when he went to 3.12. He said the issue only occurs for him on 3.12 and did not when he went back to 3.10 (which has other problems). I would search the forum for his comment to see if its the same issue you are describing. I think the thread was the Naza V2 thread.
