Wookong x2 problem
A
aap
Guest
Hi all, I am saabguyspg from RCG (trying to shake that handle)
I have a problem with the wookong m I have posted there but I am trying to find others with the same issue so that maybe DJI will respond to my problem.
With X2 connected properly I see the slider in the software jumping from current position to full right about 3x per second... and then when I try to assign it to a adjustble gain I get the program going bezurk....
I know Dixter so far has the same problem but I want to know if it's more common.
I have tried the following
DX7 with AR7000
DX7 with 6000
Thomas long range system with long range receiver and normal range receiver and both futaba and multiplex evo 12 transmitters... so it's not the transmitter.
separate BEC from DJI etc.
changing the cables
swapping the outputs
removing all channels but the x2
ultimately I have tried everything... and no luck... I am quite certain it is the unit. I have another one coming soon but they will be from the same "batch" from the factory as they were bought at the same time... so likely it could have the exact same problem in which case I will be really upset...
anyone with some suggestions?
Terry can you please look into this?
http://vimeo.com/31528495
Steve
