Wookong failsafe
VINHEX
Check in software, if you turn off controller and fail safe area turns blue set... Check throttle is above 25%
Walterone
Thanks for your quick reply
When I turn off the transmitter no matter what mode I am in it stays there
I had this problem once before but can not remember what I did to fix it.
Do you know the procedure
02deuce
Time Warped
Having the same problem this is my first time setting up a multi Rotor. I have everything working properly ie flight modes and IOC. I have my TH switch set up to go into fail safe in Manual Atti and Atti GPS modes. But when I turn off the TX it wont go into fail safe??
I am using Heli mode, Aux1 via F mode switch (setting Pitch curve values) for different flight modes. Aux2 via Aux 2 Switch for IOC modes.
Any help would be appreciated as this is the only obstacle keeping me from doing my maiden.
DJI F550
Wookong M
AR8000
Jr 9503
5000 4S Packs
VINHEX
Have you set fail-safe up using the following process..
DJI Wookong M - Failsafe set up for DX8 with the AR8000 and TM1000
When setting up the failsafe you bind everything as normal first , then set up on the TX screen in Wookong Assistant for failsafe so adjust travel on throttle so it goes over 10% and adjust whatever channel you have assigned for Manual / Atti / GPS Atti so it lights up in failsafe section this is usually Aux 1 or Aux2
Then power everything off , and insert bind plug again you can remove the TM1000 at this point ..
Power back up and wait for the receiver to start flashing then remove the bind plug (it is important you remove bind plug before powering on and pressing bind on the radio)
Now Power on Transmitter and press bind at the same time and this will pre store your failsafe settings but wont affect the original binding .
Then all you need to do is plug back in the TM1000 and go back into TX screen on the WKM config screen and take throttle back down and adjust 3 way switch etc
Once this is done you can while connected to WKM assistant switch off the transmitter and you should see the slider for throttle move to where you set it and the slider should also move into failsafe .
02deuce
Time Warped
I thought I did these steps but I will give it another try, maybe I missed something. Thanks for the fast reply!!
