Davidhippo
Hi all,
So I set up my wookong on my F550 all working well and RTH working perfectly...
Changed the servos in my gimbal a few weeks back (being fed from the main batt via a BEC, command from the Wkm) and now, bizarrely the 'copter won't RTH, whenever I hit the RTH switch it just goes up to the 20m height and hovers... Just hovers, doesn't move at all. :upset:
I recalibrated the Compass again as explained in the wookong manual that you should after every change and have even tried upgrading the software/firmware/assistant in the hope that might cure it. The 'copter flies very smoothly in all ways apart from RTH
And yes of course, I always ensure the GPS is locked/home waypoint is marked before take off and I've checked the assistant software to ensure that the RTH/failsafe is set to RTH, not hover - I've even tried the custom height RTH setting and it just hovers at the custom altitude!
Spoken to the guys at Quadcopters and they'd not heard of this problem, they just suggested re-cal of compass.
Any/all help much appreciated, thanks in advance!
Dave.
Dave.
