Im having a bit of an issue with my new S900 and the dji ground station software.
First, the S900 seems to toilet bowl very slightly at times as you can see in
especially near the end when my boss lets go of the sticks and it starts to bowl. The GPS is pointed straight to the front of the UAV.
We flew it in another area (less wind covered by trees) and it does not seem to bowl nearly as bad but it's still evident. We had it hovering relatively still, in place for a good few minutes and landed it no problem.
It's using a WKM. The IMU arrow is facing the front of the UAV, all the motors check out properly in motor testing in assistant. We hooked it up to the DJI ground station, uploaded our flight perfectly no issues. It has full satellites (flashing purple). We set it to go to 40m. It goes to 20m as it usually does (we've done this successfully with our Phantom 2 several times) and spins on it's axis trying to orient itself. From there it's almost like it's backwards. It can't seem to locate our waypoints and somewhat flies eratically.
Has anyone experienced anything like this or know where to start trouble shooting? No IOSD Mark II but the ground station software provided a gslog.dat file that appears to be encrypted and I can't open...
Also, I attached some pics of where the IMU and GPS are.
http://i.imgur.com/CGL7ZDF.jpg
http://i.imgur.com/rwBTZ13.jpg
Also, the GPS has been calibrated. Like I stated it flies relatively well without ground station minus the ... sorta of toilet bowl effect.
Gains as provided by DJI
Basic: Roll 160%, Pitch 160%, Yaw 160%
Attitude: Roll 190%, Pitch 190%, Vertical 100%
IMU GPS
-6cm 2cm X
0cm 0cm Y
1cm -21cm Z
