Wkm briefly activating fail safe
Blacksails
This has happened a few times, on a few different firmwares recently. All of a sudden the led will flash blue and ill hear the motors rev for a split second and then I'll have control again. The copter is very briefly entering failsafe and then picking up signal again. Anybody else ran into this before? It's not caused any problems as its kind of a blink-and-you'll-miss-it deal.
It's an octo running ezuhf.
Expert model destroyer and aerial photographer!
Blacksails
Definitely not that. I'm flying firmware 5.02 so the limiting option isn't available. Still my favourite FW and far more stable than the newer releases
Benjamin Kenobi
Easy? You call that easy?
If you disregard the 'revving of the motors' Is it simply a loose connection on your LED? I had a loose one which would flash blue in GPS mode occasionally (purple is made up from the different LEDS so a few had loose connections to produce blue). I wiggled it and all good again.
