WKM and Jeti Rsat2 Receiver in PPM mode
VNBN
Anybody experienced in this combination?
I just wanted to switch from a traditional Jeti receiver to a ppm model in an octo configuration, in order to free up the T & R channel for servos.
Attached the Rsat, switched to PPM but TX calibration does not work.
Movement cailbration of aileron, pitch an rudder is working fine, but throttle is not detected properly. Although I'm moving thottle down and up from -100% to +100%, dji assistant recognizes only half of the movement. In other words: the slider stops at mid stick position, although I'm pushing the stick down to zero throttle.
What is going on here?
plingboot
I had issue initially, with the yaw channel, but if you switch everything off, then back on it 'should' behave - which is what mine did.
you might need to use a jeti box to change the RSat settings to 8 channel ppm.
VNBN
Well, no change.
PPM Output Mode is Computed, RX Mode is Direct.
I turned the setup on and off a couple of times, after a time I was able to get the throttle slider down a bit more, but it still stops a line before the bottom dead end in the assistant software. Everything else is doing fine. That's frustrating.
edit: After turning off and on again, I'm back with the same problem again, slider in the middle.
