Whats the best video stabilization software?
Rick~K
Free Bird
I downloaded VideoDub and played around with it, is there others that work better? Also FREE :tennis:
RTRyder
Merlin of Multirotors
The best? Mercalli, not free but not expensive either, haven't found anything better for the times I need to use it.
yeehaanow
Hands down for me, and I've tried all. Warp stabilizer in AE. The best because it can correct rolling shutter issues.
You can rent it monthly so it doesn't cost anything in the slow winter months, and i got an email saying it was going down to $30/ month.
It's also the most intense, in terms of computer power required, and skills needed to use it to its full potential.
daniel
After effects, warp stabilizer.....works good !!! i used final cut's smoothcam, and mercalli and this Warp Stabilizer
is the one......for me.
good luck
After effects warp stabilizer produces the cleanest result for me.
Don't expect miracles. You know what they say: "Garbage in garbage out"
AlexeiD
New Premiere Pro cs6 doesn't require After effects for warp stabilizer plugin. You can download 30 day trial from adobe dot com.
They have also a rolling shutter removal plugin there.
yeehaanow
I tried the warp and still have it. Bit i had lots of croping happening video was zoomed in like 40% any thoughts?
Depends on how long the clip is and how much movement. Sometimes just to get one bad section to be as smooth as the rest the whole thing has to be zoomed in.
Try setting it on Stabilize, Synthesize edges, under Borders, then crank up the Edge feather and Synthesis input range, under advanced options.
But if your video is really bad then... what redridinghood said.
ZAxis
We use Apple's Motion which at £35 in the UK is good value considering the stabilization/smoothing is just one of many features. Only for Mac users though.
andy
