AeroSkier
More Discussion
http://click.dji.com/um7xN6F66dZYYXWt
People who fly RC drones know that there are two saddest things: crashes and flyaways. The feeling of going home with just a remote controller is awful. Of course, drone are much more reliable today than they were a few years ago, but for different reasons RC enthusiasts keep experiencing crashes and flyaways. So today, we'll talk about what to do if, however unforunately, you experience a crash or flyaway.
First of all I would like to say that the drone is a high-tech product, and right now the technology is still far from its potential, so we can’t avoid high power lines, magnetic interference, bird attacks and low voltage power offs.
First: Make sure that the Home point is set correctly.
Do this to avoid a situation in which the drone returns to the home point that was set initially instead of a new take-off point.
This can happen if the pilot moved the aircraft to another place (B point), and at the new spot, the GPS level was less then 4. The aircraft will not
record new home point. So the drone will return to A point. A lot of pilots start to panic in this situation...
Please remember to set correct RTH altitude according to your flight environment.
If the aircraft has already crashed or gotten lost.
Of course, the first thing that we have to do is to find the spot where the aircraft crashed. We will need our flight records.
Remember: All the flight records are stored in your mobile device!
Open the DJI GO App and tap on the triangle in the upper left corner:
Open the first flight record
You will find the aircraft's location on a map
After you found a crash point, head to that place and try to find the aircraft. Whether you found it or not, you have to synchronize your flight records.
Click on the cloud icon in the upper right corner.
Make sure you've synchronized your flight records!
There will be a clound icon in the corner of every flight record if it's successfuly synchronized
Please contact your local DJI support center, explain the situation, and provide your DJI ID, so we can check your flight records.
One more thing remember:Always log in your DJI ID, otherwise you will not be alble to synchronize your fligth records!
