coreyperez
What is the possiblity I stumbled upon (at least a partial cause) of the DJI Fly-Away
I was recently the recipient of a 14SG and used the two links below to setup my radio to my Naza Mv2.
http://www.rcgroups.com/forums/showthread.php?t=1973186
https://www.youtube.com/watch?v=NJ8lkBwu_AY
The Video was a 90% solution, where as the RCGroups link gave me the failsafe information. I thought every thing was good and went on my merry way. When I went to fly the MR the first time I couldn't get the motors to arm, so back to the assistant. Long story there was the Elevator was backwards, quick fix there had the motors spinning up. BUT...
On a whim I was showing a friend with the FrySky Taranis the remote failsafe-Futaba (power off/lost connection while connected to the Naza Assistant). In doing so, I had my AIL pushed left (merely on accident, when I hit the power button I noticed that the controls stayed in the "unusual attitude", (Last input). It is my belief that we (me anyway) would want my craft to come to stick/control neutral AND throttle at half/(maintain hover). My MR would have maintained last known power setting, BUT.. would have appeared to continue to "Fly-Away", at least before the failsafe kicked in.
I don't know, this MAY be the way other's would want to have their MR respond, but to me it seems exactly what we do NOT want them to do. I had to go back in to my TX and set each channel (affected) to F/S (Fail Safe) and get it adjusted properly.
I'd prompt anybody (At least those with a Futaba) to connect to the Naza Assistant, put their craft in a turn/climb, etc and kill the power on the TX to see what the assistant is going to have the MR actually do. Mine would have just kept flying in some weird direction for however long it took to kick the fail safe in. If you are expecting an immediate halt and don't get it, you start flipping fail-safe, GPS, ATT switches, power button, etc. all the while the MR is going to keep doing what it is told! It would have been your fault for the fly-away. You TOLD it to keep going, no stopping with your incorrect fail safe settings. This would be continued because you keep cycling power (failsafe), etc!!!
Keep in mind, I JUST graduated from the Turnigy 9XR (FrySky module/RX), the RX in that case was much easier to set, when the F/S was "programmed" it took exactly whatever setting the TX was sending at that time. My sticks were center (Throttle inc.), GPS activated with F/S mode selected, and acted exactly as such when the power off F/S was initiated. The Futaba was not the case. I had to go in and individually set each channel. Other radios I cannot confirm either. My radio/RX was the 14SG and R7008SB.
Open for discussion!
Corey
Corey
