Weird jerking movement (F550+Naza+GPS)
artlv99
Hi, I've been flying a F550 (with Naza+GPS) for a couple of months with a Dx8. After flying the other day and coming in for a hard landing where it tipped over and the motors strained for a second before cutting off, its had this random jerking movement when flying and hovering. I'm not sure if that landing was the cause, I've had worse and come out with no problems but it seems to have started in the following flight. I've tried swapping out motors for new ones, but its still there. Below is a link to a video I took today where you can see the issue, it seems to be dipping towards the same arm each time, though in the past it was dipping towards other arms and I swapped out a motor only to find it dipping to another arm the next time I try. Does anyone have any idea what the issue is or where I should focus my testing? Oh yeah, same issue in attitude and GPS mode.
Thanks in advance!
http://www.youtube.com/watch?v=UCEdL10BkBM&feature=youtu.be
DesJardins
If you swapped motors and the cogging moved you have either bad bullet connection/solder joints or a bad motor if all else fails.
I'd re-solder all the bullet connectors...
