VIFLY ShortSaver - New Generation Smoke Stopper
johnq816
Current smoke stoppers in market are all automative light-bulb or resettable fuse, both of them have some potential risk. VIFLY ShortSaver is a different one, it is electronic fuse.
1. Other smoke stoppers just limit not stop the current flow, the leakage current may still damage your components. VIFLY ShortSaver is a different smoke stopper that adopts the electronic fuse to completely cut off the current into your RC build if a short circuit or wiring mistake is detected.
2. VIFLY ShortSaver would turn off the power to a device that drew in excess of the switchable 1A or 2A threshold within just 10ms. It is far more effective than the old way of using light-bulb or resetting fuse. The shorter the protection time, the safer your build will be as something make break by the time the fuse trips.
For more details, https://www.viflydrone.com/smokestopper.html
johnq816
This video clearly shows how VIFLY ShortSaver can stop your build going up in smoke! It is a must-have accessory on your work bench.
johnq816
"A smoke stopper is an essential tool for protecting your quad from damage. But until now, the light-bulb smoke stoppers were less than ideal. The ViFly ShortSaver is the smoke stopper you always wanted. It's small. It supports up to 6S voltage. And it uses e-fuses (not polyfuses) so when it shuts off, it really shuts off (and it doesn't light on fire). " ------- Review from Joshua Bardwell
