Mikrokopter Tx / Rx combinations and recommendations
ovdt
Hi guys,
I'm trying to figure out which Rx / Tx solutions I should buy, but I'm stuck.
My first choice would be Graupner MX-22s but I can't find it. And I don't want to buy Spectrum DX8 Tx.
I'm gonna use Jeti Reciever RMK2 on the kopter.
So I need to get a Transmitter which is compatible with Jeti RMK2 Rx.
Jeti has modules to make the transmitter compatible with the reciever. (For instance: Duplex TU2 )
The easiest radio I can find is JR DSX9 Radio. I'm not sure if it's compatible with Jeti Tu2 tx module. Has anoyone tried this combination?
I can also purchase Futaba T10CG which is said to be compatible with Jeti Duplex TF module.
Which combinations are you using? What do you recommend?
And another question: I'm going to setup second radio for camera mount and shutter control. Does the cheap radios enough for me? (for instance Futaba 7C) Cheap radios like this has servo control?
