Hi all -
After toying around with what drone to get/build, I've decided to play it safe and buy a Phantom 2, however I plan to do some mods by adding a gimbal myself and adding FPV.
I already own a 7" HD field monitor for use with my dslr - u can see it here: http://www.amazon.co.uk/Koolertron-...-1&keywords=koolertron+monitor#productDetails
It's pretty portable and already has a battery and I'm wondering if I can save some money by transforming it into an FPV monitor - it seems a shame to buy a second monitor that simply adds wireless receivers, if I can add them myself to this one.
I've seen some posts and videos about people transforming other monitors, like this here: http://www.rctutor.org/58ghz-fpv-monitor.html
Mine however doesn't have the tv tuner component that people are replacing it with on many of the monitors they use - instead it has composite and component video connections at the back. If I was to add an aerial without butchering the case it would need to be in these ports - so would having aerials on the back of the screen be an issue as I'm assuming they'd then often be not pointing towards the sky enough.
Perhaps there's a way to purchase a unit that sticks to the back? My only concern is how messy it'd get and ideally I'd like to be able to have it take power from the monitor, so that it all runs off the one battery.
Ideas welcome. If it's not recommended and I just buy an fpv monitor so be it, but I thought it'd be worth finding out about.
Cheers!
Cheers!
