Turnigy Talon Hex vs H.A.L. Hex
I want to build my first Multi Rotor for aerial filming, and had my heart set on the Carbon Fiber Talon Hex frame. Then I found the H.A.L. which is aluminium. It's cheaper and bigger, but weighs more than twice as much. Is it worth the extra weight for a 125mm extension? Will I be able to lift more or less with the H.A.L.?
Thank you for your time.
Turnigy H.A.L. Hex
http://www.hobbyking.com/hobbyking/..._Heavy_Aerial_Lift_Hexcopter_Frame_775mm.html
Turngiy Talon Hex
http://www.hobbyking.com/hobbyking/..._Hexcopter_V1_0_Carbon_Fiber_Frame_625mm.html
