Hi I was recently balancing one of my 'Zippy compact 4s 4000mah' batteries using my 'Turnigy Accucell 6' charger/balancer after 5 secs I got an error message on the screen saying 'Cell count error'. My first thought was I had a duff battery and one of the cells had died, coincindentally I first saw this message after I had mistakenly landed my MR on a roof and it was stranded up there for a good hour or so. So I thought maybe the battery had been discharged enough to damage it.
After reading other people accounts of similar problems I decided to simply charge the battery and not balance it. The battery charged up as normal and on connecting the balance plug to my Lipo alarm it displayed all the cells having voltages of 4.2 volts within 0.1 volts of each other. I then used the battery to fly my DJI F450 Quad for around 13 mins. This all suggests to me that the battery is fine. I have charged and flown with this battery several times now with no problems.
I decided to open up the charger/balancer and take a look as I suspected that there was maybe a dry joint on the 4S balance socket. On opening up the charger I found 2 of the tracks that connect the 4S balance socket to the upright board had burnt out. I also noticed that the tracks on the main board that the upright board connects to are much wider. I've a feeling this mayebe a design fault with the charger. I am going to repair the tracks using wire and solder.
Just thought I'd post this incase anyone else has had the same problem with the Turnigy Accucell 6 and suspected their batteries being the problem.
Best Regards
Parky
Best Regards
Parky
