Tricopter Build
Angus
Angus
I'm building it at my friends workshop so I cannot show you what I have done so far. I am drilling through the center of the rear arm and inserting a rod. Then a spacer ocer the rod to allow for the servo couplings. The rod fits into two ball races/bearings inside a block, on which the motor is mounted. The servo is underneath inside the legs of the tri with a servo coupling that joins onto the motor monut.
This is quite confusing but i will try to get photos up asap.
Angus
