Transmitter model programming in heli mode for multicopters
jackmulti
Maybe this has come up before, but normally one would choose to use a fixed wing model on the transmitter for the setup of a multicopter. I for one, being a long time heli pilot, disagree.
There are several advantages to going with a mechanical ccpm heli program. Of course, that means the collective pitch channel is pretty much wasted; but on the other hand you get a hold switch to turn off all motors in case you crash and configurable idle-up curves for throttle.
In my case I use a linear throttle curve on Normal; a "motors always on" on idle-up 1, which is similar to Normal but the bottom end is such that the controller board never resets; a 50% flat curve on idle-up 2 to put my NAZA in altitude lock; and a flat slow descent curve on idle-up 3 that will land the craft safely in case of trouble.
I am extremely satisfied with this setup.
