TopXGun Releases X30
TopXGun
1. Introduction
http://topxgun.com/en/
TopXGun X30 is a set of industrial application solution for professional clients. It is a professional task system integrating technologies such as remote camera, pan tilt, digital image transmission and control, which can be widely used in fields like inspection, survey, monitor, public security and firefighting.
2. Product features
Optical zoom
With 30X optical zoom lenses and 4X digital zoom function, TopXGun X30 can photograph every tiny detail clearly 100 meters away. Equivalent focal length between 28.8 millimeters and 864 millimeters enables you to switch modes freely between wide-angle shooting and remote picturing. In practical application, there is no need for aircrafts to get close to the object and the every detail can be captured from the distance, which to a great extent makes our work easier and also safer.
Click to enlarge images
TopXGun X30 can enlarge the selected area automatically by clicking the mouse (enlarge two times by each click) while only central area can be enlarged for traditional zoom camera. It can be very difficult in practical application with the traditional way in consideration of the unmanned aerial vehicle’s pan milt motion. TopXGun X30 pod can adjust the span angle automatically and centralize the selected area to enlarge with interactive operation method, which is so easy to operate. (And it is only for static object for a while.)
Outstanding night vision
The large CMOS of 1/1.8 helps to obtain better image quality and it is so easy to get outstanding imaging effect with powerful ability in low-light conditions (color: 0.05Lux/F1.5, black and white: 0.005Lux/F1.5.) All the details can be clearly seen in both day and night, which greatly widens the application range and enhances the work ability of the unmanned aerial vehicle.
Stable picture
Extremely stable requirement is necessary for remote photography. TopXGun X30 pod adopts professional stabilizing technology to limit camera shake within 0.01°, which makes it possible to obtain clear picture even 30X focal length away. Three axis pan tilts can not only limit camera shake as much as possible but also compensate the movement of the unmanned aerial vehicle no matter how is moves, hovering or moving fast so as to get stable and fluent pictures.
Remote transmission
TopXGun X30 integrates HD digital image transmission equipment up to 8 megabit transmission stream and is equipped with standard antenna. Its transmission distance is up to 5.7 kilometers, satisfying requirement in most industries.
Making things simple
Traditional task system need separately configure image transmission module, digital transmission module, pod remote control module and so on. By doing this, these modules bring many problems like more weight, complicated electrical links and radio interference among different frequencies and impedance matching. TopXGun X30 has highly integrated transmission systems like image transmission, data two-way transmission, pan tilt control, which not only reduces equipment weight in the sky to reduce power consumption but also reduce the number of radio communication modules and the risk of interference among transmission modules and the cost of users and makes it less difficult to operate and maintain.
3. Technical parameters
General parameters
Product name
TopXGun X30
Size (length, width, height)
183*145*175mm(temporary)
weight
918g(temporary)
Working voltage
12V-25V
Power consumption
7W
Environment parameters
Working temperature
-10° to 45°
Storage temperature
-20° to 60°
Pan tilt parameters
Angle shake amount
±0.01°
Installation mode
detachable
Controllable rotation range
pitch:+60° to -120°;course:±160°
Structure design range
pitch:±175°course:±175°;roll:+90° to﹣50°
Maximum controllable speed
pitch:120º/s; course:180º/s
Camera parameters
Sensor
CMOS:1/1.8″; total pixel:600w
Camera lens
30X optical zoom F 6~180mm
aperture:1.5~4.3
minimum shooting distance:10mm~1500mm(close focus ~ far focus )
viewing angle ( horizontal ):61~2.3°
Digital zoom
4 times
Image storage format
JPEG
Video storage format
MP4
Working mode
video; picture; replay
Photograph
Single shooting; continuously shooting ; camera timer
Electronic anti-shake
supported
Penetrating fog
supported
Exposure mode
Automatic exposure; manual exposure; shutter priority exposure ; the aperture priority exposure
Screen resolution
50Hz;25fps(2560*1920)500w
Lowest light
color:0.05Lux/F1.5;black-and-white:0.005Lux/F1.5
Day-night switching mode
Automatic mode
2D de-noising
supported
3D de-noising
supported
Electronic shutter
1/3~1/30000 second
exposure
Automatic mode;manual mode
Information video overlap(OSD)
supported
Clicking zoom
supported
Clicking zoom range
1~30 times optical , 4 times digital
One-key zoom to single image
supported
Supported storage card type
Micro SD card
Data transmission,image transmission information
Frequency range
2.4g/900 megabit
Transmission distance
5.7km no shadow, no interference
Antenna gain
5db(sky) 7db(ground)omnidirectional antenna
Effective omnidirectional radiation power
100mw~1w adjustable
Video output interface
Network interface
Working temperature
-45°~+80°
