throttle only goes to 73 on kk board ?
7808
i have a hobbyking hk-t6a v2 tx, when i look in my t6config or in the kkboard reciever test, my throttle doesnt go all the way up, goes to a value of about 73 on the kk test, should it go to 99 or 100 or close ?
jbrumberg
I really do not know your Tx. On my Tx there are trim and sub trim settings yours may have them too. One really does not want to tie up the trim settings with a set up issue, but I am guessing here for solutions. It is really basic Tx and not user friendly. I have another question. Can you mechanically adjust the throttle by some adjustment screw? Or can you cut out an indent at the top of your throttle range so you can physically increase the range of the throttle stick movement?
mbowser
My memory my be failing me here, but I believe I had a similar issue that worked itself out once I properly calibrated the escs.
But I had so many issues when I first got the board that I might be confused
Good luck
jbrumberg
Thanks Matt I "calibrated" a couple of times just to make sure it was calibrated. All that bleeping beeping was making me crazy.
7808 good luck on this. I really am at a loss with this Tx of yours. Something is not right.
