Motoxer311
http://www.BuiltDrones.com/products/dji-spreading-wings-s1000-octocopter-1.html
DJI Spreading Wings S1000+ Octocopter
Need a custom build? Call and we'll get your order going and shipped ASAP! (904) 800-7725
Spreading Wings S1000+ Introduction
Large Carrying Capacity
Free yourself from weight limits and fly with heavy DSLR cameras such as the 5D Mark III with the advanced
eight-rotor propulsion system of the S1000+.
Compatible with Zenmuse Gimbals
Full compatibility with DJI’s entire line of Zenmuse Z15 camera gimbals, including the new Z15-5D III (HD), provides unmatched stability in flight. Strong and Stable The S1000+’s arms and landing gear are made of sturdy carbon fiber, giving remarkable stability and strength. You’re flying in a variety of flight conditions with confidence, knowing your gear is safe.
Highly Portable, with Foldable Arms
With arms that fold in to save space, the S1000+ is built to be taken wherever you need to go. Then when
you want to fly, you are ready to start shooting in just a few minutes.
New Power Distribution System
A redesigned, rebuilt power distribution system improves safety and reliability. Gold-plated metal bearings
secure the power cords, ensuring cables will not come loose during flight and allowing easy setup.
Removable Upper Center Board
The upper center board can be removed, giving you access to the IMU. Additionally, there are eight positions reserved for your extra equipment. So installation of your main controller, iOSD, Lightbridge, or any other accessories is faster and easier than ever before. This new center board structure is perfectly compatible with the DJI WKM and A2 flight controllers.
Professional Quality
Weighing just 4.4kg, the S1000+ has a maximum takeoff weight of 11kg. This means you can easily carry most cameras and gimbals, including your 5D Mark III. Used with a 6S 16000mAh battery, it can fly for up to 15 minutes.*
*Maximum flight time is tested on a windless day with a payload of 6.8kg, hovering at a height of 2 meters.
Flight Time
15 Minutes
Takeoff Weight
Maximum: 11kg
Wide Range of Shooting Angles
Retractable landing gear and a low gimbal mounting bracket combine to enable a wide range of possible
shooting angles and camera motions.
Reduced Vibrations, Clearer Footage
The S1000+’s gimbal bracket is separated from the main frame by specifically designed dampers. This
significantly reduces high-frequency vibrations and makes your shots clearer and sharper.
Sparkproof Plug
Prevent short circuits and easily plug in your power supply with the AS150 sparkproof plug.
Innovative Arm Design
Each arm is designed with an 8° inversion and a 3° inclination, making the aircraft more stable when rolling
and pitching, yet more flexible when rotating.
Greater Power
A 40A electronic speed controller (ESC), our fastest available, is built in to each arm. Combined with its 4114
pro motors, high performance 1552 folding propellers, and V-type mixer design, the S1000+ has a maximum
thrust of 2.5Kg.
Our latest motor adopts a single wire stator design, offering improved heat dissipation, better performance,
and a tidier, more reliable system.
Flight Time
15 Minutes
Takeoff Weight
Maximum: 11kg
Sparkproof Plug
Greater Power
thrust of 2.5Kg.
