henrysj
The Dominator iCharger 4010 Duo Charging Station
*** 3000W @ 48.8V ***
Unleash the full potential of the world's most powerful heavyweight charger with this custom built Charge Station.
With 3000 Watt @ 48V on tap the Dominator not only allows the iCharger to reach its maximum output but makes for a more stable operation as it will always be in voltage step-down mode. With two channels each able to charge at up to 40 amps simultaneously, it's like having two supercharges in one.
Or combine both channels in parallel to achieve up to 70 amp charge rate!
Dust & Waterproof Flight Case
(no exterior holes or modifications)
Dual Front Storage Boxes with Hinged Lids
Dual USB Ports
(for GoPro, Iphone, iPad charging)
**optional**
The Dominator comes fully assembled in 4 options:*** 3000W @ 48.8V ***
Dual USB Ports
**optional**
1) 3000W Charge Station & iCharger 4010 Duo £630
2) 3000W Charge Station, iCharger 4010 Duo & Dual USB Ports £650
3) 3000W Charge Station - ready for you to insert your iCharger 4010 straight in - no modifying required £380
4) 3000W Charge Station & Dual USB Ports - ready for you to insert your iCharger 4010 straight in - no modifying required £400
**** If you choose it with the iCharger 4010 it comes with a brand new iCharger, it's original box, cables and 12 months warranty ****
As the case is custom made to order please allow up to 5 days before shipping - Shipping to the UK £10, internal shipping rates on request.
If you have any requests or alterations you would like to make, please contact me and we can discuss them further.
Cheers,
Henry
