As another member suggested, sum of the specs to to the quad may help in determining the right battery and speed controllers.It has max lifting efficiency of 12g per Watt? It has 12 inch nylon props.It has a take-off weight of 950 grams. with a max payload, camea, ect, is 1800 grams at take-off weight. It dosnt say what the motors are rated for, all it suggests is a 3S Lipo battery. Would that help in determining a recommended speed controller and\or battery? A 20 C 2200mAh or bigger? O, quad size is 608mm x D 608mm x D 243 mm. It has (4)700KV motors.I have a naza -m for it too.
