We've (courtesy of Ben Rowland) got a review of Teradek's Clip and Bolt Pro 2000 just about ready to publish and since getting to know Teradek a bit we've become fans. Here's the brochure they've released announcing expansion of their Bolt Pro line of HD video TX/Rx systems and the text of a recent Facebook update,
.pdf download...
https://www.dropbox.com/s/nnvusl0mh5zmnpt/Bolt Pro NAB 2014.pdf
facebook announcement copied below and also available here...
https://www.facebook.com/Teradek/posts/10152317998403571
www.teradek.com ❘ [email protected] ❘ 888.941.2111
Uncompressed Wireless HD Video
The Teradek Bolt line of latency-free wireless video transmission systems allows you to send uncompressed
1080p60, 4:2:2 video up to 2000ft over the unlicensed 5GHz band. Bolt Pro is multicast capable
up to 4 receivers and comes in many varieties, including the short-range Bolt Pro 300, the mid-range Bolt
Pro 600, and the long range Bolt Pro 2000.
Bolt Pro 300
The Bolt Pro 300 is the latest update to the best selling Bolt Pro line, off ering both HDMI and 3G-SDI inputs on the TX
and an improved chassis design that runs cooler. The 300 model maintains internal antennas, which cannot be augmented.
The model 300 receiver off ers a fan-less design that runs absolutely silently while remaining cooler than previous Bolt
systems. The new RX has both HDMI and 3G-SDI outputs, a LEMO power connector, and internal antennas.
Bolt Pro 300 Bolt Pro 600 Bolt Pro 2000
See all of our products at teradek.com
GRAB™ Video Engine
The Bolt Pro 600 and 2000 support the
optional patent-pending GRAB video
ingest engine, which turns the Bolt Pro
receiver into the world’s fi rst wireless
video capture card. With both 3G-SDI
and USB 3.0 outputs, users can ingest
Bolt’s uncompressed 10bit RGB video
feed directly into a DIT Cart, NLE
computer or live production switcher
with no added delay or further
conversion required. Since the GRAB
engine supports the ubiquitous USB 3.0
Video Class, your Bolt Pro receiver with
GRAB engine appears like a built-in video
source to your software and will work in
any Windows or Mac applications that
support video. The Bolt Pro receiver
with GRAB comes in the same fan-less
chassis as the standard model 600 &
2000 receiver and includes a built-in
LCD for checking your link status and
pairing additional Bolt receivers while
you’re on the go.
Patentpending
Bolt Pro 600
The Bolt Pro 600 uses a new RF design that
extends the transmission range up to 600ft
line of sight. The TX also includes 2 RP-SMA
connections that can be outfi tted with higher gain
antennas to provide a more resilient wireless link
over longer distances. Best of all, the 600 model
includes both an HDMI and 3G-SDI input so you’ll
be able to use it just about anywhere.
Bolt Pro 2000
The Bolt Pro 2000 increases the line of sight range all the way up
to 2000ft and includes both HDMI and 3G-SDI inputs so it can
function on any modern camera rig. Like the 600 model, Bolt Pro 2000
can also be augmented with high gain antennas for increased range
and resiliency and includes a 3G-SDI loop for added fl exibility.
Updated Receiver Design
The new standard receiver for the Bolt Pro 600 and 2000 models is half the
size and weight of the previous long range receiver and off ers both HDMI and
3G-SDI outputs. The new fan-less chassis design also includes a built-in LCD
for checking your wireless link status and pairing additional Bolt Pro receivers
in the fi eld. As an added benefi t, 5 RP-SMA connections are included so you
can augment your system with high gain antennas for increased transmission
resiliency.
.pdf download...
Bolt Pro 300
GRAB™ Video Engine
you’re on the go.
Patentpending
Bolt Pro 600
Bolt Pro 2000
resiliency.
