Tarot triple 680MM plates
Chalagi
Any Tarot 680MM hexa that uses triple plates mostly for the esc placement? Also on the 680MM does anyone replace the standard 10MM carbon camera rail tubing for longer tubing to get the props and arms out of the camera view?
Chalagi
That's a really nice rig you've got there AzViper. Do you have a link for the 10MM carbon carriage tubing? And what is your AUW on the big quad?
Chalagi
Thanks for the link Az. For my Tarot I'm trying really hard to keep the AUW at around 2900g or less. The motors that I'm using on the Tarot are DYS BE4108 580Kv 821 Watt and the max prop size is 13x6.5 so I"m kinda limited to the prop part.
Chalagi
Wells its not the hexa as much as it is the motors. Max props on my motors that I can run are 13x6.5. But if I were to get the standard motors that most guys use on the Tarot 680 the only thing I would be gaining is in the Amps that it uses.
I extended my gimbal mounting rails and it only worked out so so. It made it so forward heavy that I had to really move my battery back to counter the imbalance. And I still get the props in the picture but not all the time. I finally just canted the camera down just a little and that took care of the problem.
