Tarot IRON MAN 1000S Oct-Copter Frame Set [TL100C01]
TAROTRC
Product Description
  • The latest Oct-Copter UAV of TAROT. Newly add plastic motor mount and heightened landing skid.
  • 100% TORAY 3K carbon fiber applied, CNC processed
  • The quality of 2.0mm thickness matte carbon fiber is higher than products available on market.
  • The motor mount is reinforced PC injection processed.
  • Lightweight design, dual-color, which can be recognized easily in the air
  • The whole set is only 1.65 kg weight (include landing skid)
  • Payload is up to 5 kg, which is specific for 5DII, RED EPIC, C300, FS100, FS700 and large-sized photographic equipment
  • Specification:
  • Boom Diameter: 25MM
  • Diameter (motor to motor): 1160MM
  • Frame Diameter: 1250MM
  • Height: 400CM
  • Central plate: 250x240 MM
  • Applicable Propellers: 15-16 inches
  • Motor installation: 16MM/19MM/25MM/27MM equilateral triangle installation
  • Weight: 2.05KG (package included)
Package Content:
  • Pure carbon fiber upper plate (250x240x2.0MM) x1
  • Pure carbon fiber lower plate (250x240x2.0MM) x1
  • M3 nut x48
  • Pure carbon fiber battery mount (220x63x2.0MM) x1
  • Pure carbon fiber adapter (73x73x2.0MM) x1
  • M3x35MM (H7) hex aluminum bolt x6
  • M3x12MM (H7) hex aluminum bolt x4
  • Pure carbon fiber ESC adapter (35x38.6x2.0MM) x16
  • ¦µ25MM 3K pure carbon tube (495MM)
  • Metal ¦µ25MM motor mount x8
  • M3x24 cup head hex collar screw x24
  • Pure carbon fiber side plate of landing skid / left (345x150x2.0MM) x3
  • Pure carbon fiber side plate of landing skid/ right (250x240x2.0MM) x3
  • ¦µ25MM boom clamp x60 (dual-color)
  • M3x35 cup head hex collar screw x60
  • Vibration absorbing foam x3
  • M3x10MM aluminum bolt x3
  • M3*5MM button head socket screw x18
  • M2*18Mm cup head hex collar screw x3
  • M2 lock nut x1
  • Dual-color sticker x4
  • Large-size water sticker x8
  • Battery Velcro strap x1
  • Instruction manual x1
attachment.php
attachment.php
attachment.php
attachment.php
