Building my first multirotor and decided on the tarot 650 sport. Instructions are sparse at best and I have a couple of questoins.
1. Wiring the retracts. I'm confused on how to wire the control unit (or what ever it's called). The 2 small white ports on each side (only 1 is visible in the pic) go to the legs and I assume the black and red wires are for power. But where do you hook it up to get the power? Also what are the 2 ports on the front. See pic.
2. The mounts motor can be rotated along the arm. Is there an optimal angle they should be facing? Should it be just straight up? In either case how do you best find that angle?
