Taranis Naza M F550 Channel setup
FlaBouy
Ok guys, getting ready to go into the weeds a little deeper on the Taranis, but before I do, I want to bump my channel selection off of some of you more experienced hexaholics... anyone can chime in with pro's and cons on my layout and programming.
My Rig
DJI F550
Naza M V1 with GPS
DJI 2212/920's
DJI carbon Fibers
AeroXcraft feet and 2D Gimbal
3S 5500maH x 2
Taranis X9 with X8R
At the moment, I have the Taranis calibrated and talking to companion9X and I have looked through the V-Sen with Naza Assist 2.2
Here is my roadmap:
Chnl 1 - Ail
Chnl 2 - Ele
Chnl 3 - Thr
Chnl 4 - Rud
Chnl 5 - Camera Gimbal - Roll Switch SG
Chnl 6 - Camera Gimbal - Gain Slider 2
Chnl 7 - IOC on Inverted Switch SC
Chnl 8 - Man/ATTi/GPS - Switch SD
Custom switches
TX Volume - SL1
Norm/GPS Hover - SA
Norm/Failsafe - SF
Naza Gain X1 - S1
Naza Gain X2 - S3
I have already bound the receiver and done a primary setup of channels per this guide: http://www.multirotorforums.com/sho...tructions-for-FrSky-Taranis-X8R-and-Naza-M-V2
At the moment, I don't have the Control mode working in the assistant or the failsafe but I believe it is due to me setting up the channels and verifying the wiring at the receiver. Using the basic setup I can drive the roll on the camera gimbal with the SG and move the gimbal in pitch by manually setting a negative gain in the assistant.
So since I was going to go back to the receiver and verify wiring, I thought I might as well map out my channels and set it up next pass now that I know my way around the radio menus.
I thank you in advance for your comments and sarcasm.
