T5-700 Airfoil Copter-With JR 9503 2.4 GHz Radio and more
Skyhigh123
COPTER T5-700 BY AIRFOIL AERIAL SYSTEMS SOLD :nevreness:
This T-COPTER INCLUDES the following!
AirFoil T5-700 T-Copter
T-Copter with JR 9503 2.4 GHz Radio
This T-copter is designed around solo aerial photography (AP) shooters with an INCLUDED world class JR 9503 9 channel radio system. It could also very easily be used by a team (Pilot / Photographer) with the use of an additional (not included) radio system.
This T-copter is set-up to fly with a typical Digital SLR camera up to massive 2 1/2lbs. in weight!
Perfect system for professional photographers want to shoot high quality still images or video’s. Four (4) large lifting motor’s and a single (1) tail motor it's very ready to fly. The ESC’s are of the highest quality. The T-copter has quality ball bearing tail system that uses a tail lock and on the fly adjustable flight control system. The frame is all aluminum and CNC'ed constructed. Includes four (4) APC props. I'm also including two (2) 3S 5000mah Lipo battery packs to get you going and off the ground.
This system includes the self leveling auto pilot that was installed at AirFoil. This unit will let you release the cyclic sticks at any time to have the T-copter level itself out with the horizon. This self contained system never needs to be calibrated. This system is not an IR unit so it never requires light. T-copters can be flown over water, indoors, and outdoors. T-copters are very versatile and can be flown in temperatures of -30 to +130 degree's. The auto pilot auto adjusts for temperature changes and weather conditions. T-Copter's have a low parts count and only uses the highest grade parts. This helps to eliminate crashes due to parts failures and drift caused by flexing or payload stress. This system is designed to give you the best payload and performance for the money.
JR 9503 2.4GHz Transmitter Radio Specs:
Combining Spektrum’s industry-leading 2.4GHz DSMX® technology with the proven JR 9303 DSM transmitter programming with optimal features creates this impeccable radio.
Additional features such as 50-model memory, ModelMatch, and being back-compatible with all Spektrum receivers make this model a great value.
Furthermore, the highly requested throttle timer start-up feature added to the advanced functions of the X9303 and a backlight screen also increase visibility and readability on the display. This provides top-of-the-line features to this already great radio. Enthusiasts can appreciate this JR radio regardless if a beginner or experienced hobbyist.
This UNIT INCLUDES THE DSM2 JR R921 RX RECEIVER!
The key features of this receiver are:
- 9 channels
- Patented DuaLink®
- SmartSafe™ fail-safe system
- Two types of fail-safe
- Flight Log compatible
The JR R921 receiver combines Spektrum’s exclusive, patented DSM2 protocol—plus the brand’s patented DuaLink® technology The result has been revolutionary! The radio system simultaneously transmits on two frequencies, creating dual RF paths. This dual path redundancy, plus the fact that each of the two receivers is located in a slightly different location, exposes each to a different RF environment and creates a superior path diversity RF link in all conditions.
You can find additional information at:
AirFoil Aerial Systems
http://www.airfoilskycam.com
***NOTE*** THIS T-Copter is NOT A TOY. . Due to the nature of this hobby this equipment is being SOLD AS-IS with no warranties.Some sodering and programing will need to be done on the left 2 ESC's and motors caused by an "oops" landing tip-over!Frame is in good condition.I bought 1 esc online and not sure if its the same as the others.Let me know if you have any questions.Would like to go threw ebay for payment.Thanks gView attachment 6752 View attachment 6751 View attachment 6753
