I have two other large multicopters, a F550 and 1000mm octo, both came as ARF kits so motor/prop/voltage was already done. I am now looking to purchase a Stealth2o-H quadcopter that is 585mm across, and wondering where I should start.
http://www.stealth2o.com/
I plan on using my existing pixhawk w/ telemetry, 1.3 Ghz FPV, AR9020 receiver, and gopro hero 3+, and eventually a gimbal which I can use the gopro in its waterproof shell. So its not exactly lightweight. I have read that you can use upto 15" propellers on it, if need be.
I looked around ecalc, and I didn't see the RCtimer 4108 motors I use on the octo, nor some similar turnigy motors on there either. How can one use ecalc, if the motors you want are not listed there (I even checked the paid version listing).
So can anyone suggest a motor, prop, voltage combo that would be a good starting point?
