One of the problems with image stabilization systems inside of the lens is that of recognizing movements which are intentional and those which are not, for example, if you are making a slow pan movement then the lens will hang onto the first position and then let go of it, resulting in jump or an unequal rate in the movement. This is probably what DJI are getting at with this fixed lens aspect.:tennis:
Canon for example recommend turning off IS when a tripod is used.
