Hi There,
As I understand it, the higher the voltage run on a multirotor, the higher the efficiency. I currently run 4S with 770Kv motors on an octo. It seems that it would make sense that I could run these motors on a 6S battery (my ESCs are 3-6S capable), and limit the throttle so as to not overspeed the props as opposed to go to bigger motors with lower Kv. My 770Kv motors provide plenty of thrust are lighter than lower-Kv-range motors so would I not get great efficiency by powering them with higher voltage? And since less amperage is required, wouldn't everything run cooler? I have heard that speed controllers do not like operating at low throttle settings - why is this? Hope someone can shed some light on why or why not I should go to a higher voltage. I'd really like to get a better sense of what goes on in the ESCs and how they provide power to the motors.
Thanks so much!
Best,
Duncan
Thanks so much!
Best,
Duncan
