Welcome To DroneVibes
Sony a7rii yuneec tornado h920
Discussion in 'Aerial Photography and Video Discussion' started by Earthmech, Jan 7, 2018.
  1. Earthmech
    Earthmech New Member
    3
    0
    1
    Jan 7, 2018
    Australia
    Posted by Earthmech, Jan 7, 2018 #1
    Hi,
    I have a yuneec tornado h920 with the cgo4 camera/gimbal. The hexacopter is quite good but the camera/gimbal and video transmission is poor. I want to fly it with a sony a7rii. What would be the best gimbal and video transmitter/receiver to use for reliability and a solid 1 mile range? What would be the easiest to set up so i can still run the copter and camera through 1 remote?
    Tags:
  2. DroneTalk
    DroneTalk R/C Expert Staff Member
    470
    42
    11
    Jul 8, 2015
    new jersey
    Posted by DroneTalk, Jan 7, 2018 #2
    Well if your flying the the US 1 mile would not be LOS, but any 5.8 ghz with proper ant will do .
  3. Earthmech
    3
    0
    1
    Jan 7, 2018
    Australia
    Posted by Earthmech, Jan 8, 2018 #3
    Thanks Drone talk, I'm in Australia and we still have to fly line of sight. Point is it needs to be a stable signal. The standard drone come with 5.8 ghz but any more than about 200mtrs and it will start dropping out. I have improved signal a bit with an itelite antenna on remote and ran external antenna on the drone. Still very average at best
  4. Old Man
    Old Man Active Member
    Posted by Old Man, Jan 24, 2018 #4
    Something’s not right with your range. I fly a 920+ and regularly go out 550+ meters with no issues. I’m U.S. and don’t normally use metric measure but 1600’-2000’ is common for me.
    Adapting a Gremsy gimbal and Connex for video transmission would be a good direction to go. You would want to add a small, separate FPV camera and vTx for guiding the 920. The bird will handle the weight.
    Unfortunately the batteries Yuneec is selling are crap and are breaking down from the first time you use them. Some battery experimenting has established Zippy Compact 5000mA, 25c batteries from HobbyKing are sized small enough to easily place two in the battery bay. Flying very aggressively I have obtained 25:39 in flight time with them. You have to make plug adapter wires to use them.
  5. Earthmech
    3
    0
    1
    Jan 7, 2018
    Australia
    Posted by Earthmech, Jan 24, 2018 #5
    Thanks Old man! That is some very helpful information. Good to hear your 920+ is going well. 25min flight time is great for a bird that size.
    I have found the internal antennas on the cgo4 gimbal and I'm going to experiment with running external 5.8ghz antennas to see if that improves my range.
Loading...
Share This Page
Loading...
