Sony 1/3" 800TVL Camera Power LED Modification
Just about every board in the Blackout Mini H Quad has an LED to indicate it's powered up (ie; Naze32, Bluetooth, VTX), except the Sony 1/3" 800TVL Effio-V FPV camera.
After clipping a tree branch (which actually dislodged the FPV camera out of the frame), the FPV camera became very intermittent, which turned out to be a broken power supply wire.
It would be nice to know if the FPV camera was actually powered up (or not) with a power LED.
To do this mod, you WILL need advanced SMD skills, a fine tipped soldering iron, fine solder, a maggy lamp, as well as the SMD parts... but you already knew that. ;-)
First thing to do was check the camera board with a multimeter to see if the +12V appeared at a convenient point to pick off.
Power was found across an 0805 ceramic bypass cap, just above the 3-way Video/GND/+12 connector.
As luck would have it, some reclaimed 0603 1KΩ resistor were on hand, as well as some tiny SMD LEDs.
0603 parts are small. You can see the difference in size above, compared to a regular through-hole 0.6W 1% metal film resistor.
The SMD LEDs compared to a standard 5mm LED.
Basically, we fit the LED in parallel with the ceramic capacitor (ie; across the supply line) via a 1k resistor.
I found it easy to work on the camera, if it sits on top of another roll of solder, like so:
I'm actually modifying both of my cameras in one session, so there's a mixture of photos. The camera above has been protected against moisture (damp grass etc) with lacquer, as detailed in a previous article.
Once you have ascertained it's polarity, tack the LED in place with a small dob of superglue, and fit using tweezers:
Testing. Camera plugged into the loom:
The actual flight camera (the one sprayed with lacquer), modified, and installed back inside the Blackout frame:
Very easy to instantly see whether it has power, or not.
Why don't the manufacturers do this already? !!!
Providing you have the required SMD soldering skills this is an easy mod, albeit fiddly, to do!
nathes2016
GOOD
_____________________
The 16th China International Lighting Fair (Autumn Fair) will be held from 22-26 October, 2015 at the Guzhen Convention and Exhibition Centre in Zhongshan City, Guangdong Province.
The 16th China · Guzhen International Lighting Fair (Autumn Fair) has already started to register,we believe that its success will bring important opportunities and recognition for Guzhen and greatly boost prospects for the lighting market and advancing the lighting industry!
Contact Person:[email protected]
