lol...yeah... I only bought six for my Hexa. sigh...Always a good idea to have all sorts of spares on hand HOWEVER, IF a nut came off in flight, you're probably gonna need way more than spare nuts to get it back in the air.
What kind of washer would be apropriate for use with the stock DJI motors? Plain or lock washer? Does it need balancing?
Thanks everyone for this info.
Bernd,I've changed out the pretty aluminum bullet prop nuts with NyLock stainless steel self locking nuts.
No worries about them loosening, EVER.
If you need any, they are 6mm X 1 thread for the DJI 2212/920 motors.
For the Graupner 10x5 props, they needed either a 6mm flat washer on top of the prop, or an 8mm washer under the prop.
Your choice.:shame:
Have a read at this:
http://www.bikeradar.com/gear/article/workshop-why-torque-wrenches-are-invaluable-24917/
It's not specifically about Multirotors, but you get them in all different sizes, and considering the price for a pair of Top range blades......it's a good investment
Thanks for the article. This is good information. We never know how tight is tight. How do you know even when using "common sense"? It seems losing a prop or having them break in flight is something that often brings multirotors down. There seemed to be a debate on what side the washer went on for a minute.
Hey nosedive
You're absolutely correct in your statements regarding the Graupner props and the nylock type nuts, there is NOT a lot of surface contact between the nut and the top of the prop. I was having some trouble getting ONE of the props to lock down tight. Apparently DJI's machining tolerances are not perfect. The 2212/920 motor shaft on this one motor was very slightly different from the other 3, so that caused me to need a washer to raise the prop up a bit for a snug fit on the nut.
Something else I noticed yesterday on the Graupner props is the top of the hub has "Made In Germany" molded on it. These letters are slightly RAISED which really cuts down on the nut to prop contact surface. I carefully smoothed these letters away so that the hub is now smooth, allowing a full contact.
The Nylock nuts I'm using require a 10mm wrench. I am trying, unsuccessfully so far, to find a larger sized nut in the 6x1 size, so a larger surface contact.
Hey nosedive
