Welcome To DroneVibes
Sleepy Reviews Insight 5G 1080P 100mW Full HD Digital Video Transmission System
Discussion in 'Member Drone Product Reviews' started by SleepyC, Jan 19, 2017.
  1. SleepyC
    SleepyC www.AirHeadMedia.com
    1,709
    342
    66
    Posted by SleepyC, Jan 19, 2017 #1
    DOWNLOAD APP and MANUAL:
    http://www.argusfpv.com/downloads.html
    If you would like us to review a product please email stephen@airheadmedia.com
    Link to Product: https://www.foxtechfpv.com/insight.html
    Product info:
    Features:
    5G FHD Digital video transmission
    Input support up to 1920*1080@60fps,Output support up to 1920*1080@30fps;
    Use the 5G radio technology, TX power 100mw(CE certification and FCC certification);
    Ground control with the 5db omnidirectional antenna (standard),transmission distance over 2-3 km;
    Ground control with the 14db directional antenna(custom), transmission distance over 5km;
    Input and Output:
    HDMI Input
    5G WI-FI FHD Output: Android phone, Pad can be used as a monitor after connected the APP.
    Anti-interference
    Up link/Down link Using MIMO multi antenna technology and OFDM modulation mode, with advanced algorithms, and effectively improve the stability of the system data bandwidth and complex environment, improve the dynamic performance of the system;
    Down link real-time monitoring of each channel interference state, dynamic selection of optimal channel work (up to 24 transmission channels);
    supporting up to 24 devices working at the same time;
    Low latency
    System maximum time delay 80ms;
    OSD function
    Built in OSD function, you can achieve the information function with the APM pixw pix without the external OSD.
    Bundled flight controller
    Without any restrictions on the APM pixw APP pix built-in digital transmission.
    Multiple mode and information secure
    Ground side can link over two devices.
    To ensure that information only through the ground side of the authorized frequency of the encryption transmission video data can be received.
    Battery and charge
    Ground side built-in 1300mAh large capacity battery, the device can work continuously for 2 hours, can be charged by power bank.
    Sky control input voltage 5-18V
    Product specification
    Video input: HDMI
    Support format(HDMI):720P 50fps;720P 60fps;1080I 50fps;1080I 60fps;1080P 25fps;1080P 30fps;1080P 50fps;1080P 60fps;
    RF parameters: 5GHz,FCC certification
    Interface(Ground control):LED, power switch, charge input, USB 2.0
    Interface(Sky control):LED;HDMI input;PWM output;TTL transmission;
    Material:Aluminum alloy
    Power (Ground control):DC 5v; Build-in battery; Watts: 6W
    Power (Sky control): DC 5~18V; Watts: 8W
    Size (Ground control): 69*49*16(mm)
    Size (Sky control): 67*37*20(mm)
    Weight (Ground control): 100g
    Weight (Sky control): 70g
    Transmission distance(outdoor): with the 5db omnidirectional antenna(standard),transmission distance over 2-3 km, with the 14db directional antenna(custom),transmission distance over 5km
    Output delay:80ms/0.08s
    Band frequency:5.1GHz-5.8GHz
    Modulation mode:MIMO-OFDM
    Video input:Micro HDMI
    Compatible input video format:HDMI all format, up to 1920*1080P@60
    Output format:640*480p@30@60,1280*720p@30@60,1920*1080p@30
    Compression:HEVC High definition television broadcasting
    Channels:24 channels(Automatic frequency hopping, anti-jamming)
    Support devices:phone,Pad,PC
    Support system:Android,ios,Windows
    Data interface:UART data transmission interface
    PWM control interface:4 PWM control output, you can control the gimbal and other external devices.
    Communication encryption:256bit encryption
    Temperature:-10℃-60℃
    Certification:FCC Certification
    nathan and droneadmin like this.
    Tags:
  2. Av8Chuck
    Av8Chuck Member
    953
    81
    11
    May 28, 2011
    Posted by Av8Chuck, Jan 20, 2017 #2
    Hi Steve, I was curious about this but was skeptical and haven't had the time. Thanks for the review.
    Too bad about not working with iOS and no HDMI out. You mnetiond it's compatible with the Pixhawk, what does that get you?
    I love the Connex but I really like the idea of using this with the a6500 or GH4 on an H3. Should be good enough for industrial inspection.
  3. jfro
    jfro Aerial Fun
    983
    59
    11
    Aug 23, 2011
    Upstate NY.
    Posted by jfro, Jan 20, 2017 #3
    Can't wait to see your distance with it in the air. Thanks for the review.
    As to the tablet, the Nividia K1 tablet ($200 ) would be the go to tablet for this as it has an HDMI out jack for the screen, has an micro hd slot, plus it has an extremely robust screen recorder which uses very little cpu as it''s done on their chip. I have some expensive goggle that I fly with and just got a Mavic which took the hdmi off the remote, so need the same type of setup. They are claiming 2-3km with the stock antenna's so if it gets 2 it should be good for most peeps that fly bigger rigs assuming they don't often fly great distances away... What's you distance on you Connex? (not the fpv version) .
  4. SleepyC
    1,709
    342
    66
    Posted by SleepyC, Jan 21, 2017 #4
    Well the unit has a whole nother software kind of like a DJI GO, and it looks like it uses the data from Pixhawk to fill in the blanks of the app. It allows waypoints, and things like that. The instructions are terrible so until I get someone with a Pixhawx I don't know.... exactly.
    SOON I hope. Trying to fly it today or tomorrow to get range checks.
  5. SleepyC
    1,709
    342
    66
    Posted by SleepyC, Jan 27, 2017 #5
    I got it in the air, look up EPI #9. On my Channel!
  6. jfro
    jfro Aerial Fun
    983
    59
    11
    Aug 23, 2011
    Upstate NY.
    Posted by jfro, Feb 13, 2017 #6
    I bought one and IMO, so far it's a waste. Terrible design with the connections for the antenna. Those are connection for tied down inside of a box, not dangling from a moving flying machine. I'm getting intermittent video on the preview and as I'm' testing it, the friggin fan motor has started making noise. Big disappointment.
  7. SleepyC
    1,709
    342
    66
    Posted by SleepyC, Feb 13, 2017 #7
    Weird.
    I've had great luck! (And I paid for mine)
    I did hot glue the antenna connections... but they have been fine.
    Had it out probably 750 - 1000 feet no issues.
    I can say it's picky with Tablets. make sure to use a powerful one.
  8. jfro
    jfro Aerial Fun
    983
    59
    11
    Aug 23, 2011
    Upstate NY.
    Posted by jfro, Feb 13, 2017 #8
    even with hot glue, the antenna's are going to be problematic. Those are the same connections they use on the wifi connection inside our laptop computers. Wouldn't have cost much (a few pennies) t0o make a more robust antenna connection...... Those are just insanely poor.
    Trying to figure out why it transmits one minute and not the other. Will try some other tablets, although I want it to work with the Nvidia k1 so I can use the Glyph Avantes. No problem framing with them and keeping LOS on the MR. Will look a little closer to see where the fan noise is coming from. More than likely, will go back to China which is a long round trip .
    I'd be very happy with 1,000 feet... on my x8's.
  9. Av8Chuck
    Av8Chuck Member
    953
    81
    11
    May 28, 2011
    Posted by Av8Chuck, Mar 2, 2017 #9
    Did you ever sort out the issues?
  10. jfro
    jfro Aerial Fun
    983
    59
    11
    Aug 23, 2011
    Upstate NY.
    Posted by jfro, Mar 3, 2017 #10
    Sort of.
    I have it working but haven't flown to see the range. Blackmagic micro cam kicks into SD when overlays are on. Does me no good. There is more lag then I have on the Inspire and Mavics previews. Going to be windy for a few days so no flying for a while. Hit 60 mph yesterday.
    Image looks pretty good in Avante Glyphs if I use Shield k1 tablet. Wish I could flight data overlayed on the hdmi down link, then this would be a great value setup.
  11. apvmultirotor
    apvmultirotor New Member
    1
    0
    1
    Jun 9, 2015
    USA
    Posted by apvmultirotor, Apr 8, 2017 #11
    Cannot see WiFi network it supposed to create. Is there step need to be performed?
    Sent from my Nexus 5 using Tapatalk
  12. betty
    betty Member
    57
    0
    1
    Mar 27, 2017
    US
    Posted by betty, Apr 12, 2017 #12
    Thanks a lot for your review.
  13. Av8Chuck
    Av8Chuck Member
    953
    81
    11
    May 28, 2011
    Posted by Av8Chuck, Apr 16, 2017 #13
    Got it working, worked well during a 500' test flight, but when I went to fly it again I noticed one of the antennas on the Tx just fell out.
    I guess you get what you pay for...
Loading...
Share This Page
Loading...
