Hello everybody,
Let me introduce you with the smallest gimbal motors for your Mobius/Dimika and Small HD Camera DIY gimbals.
1806-80T -- 17.5gr
2204-100T -- 19.5gr
You can make your own the lightest and the smallest DIY HD camera gimbals with them.
http://fpvline.com/store/index.php?id_category=41&controller=category
We also want to introduce you with our brand new SkyPro RC single wire winding motors. SkyPro x2204 2300kv , x2208 1970kv. and 2312 1100kv.
You can order them from http://fpvline.com/store/index.php?i...oller=category
At first i want to mention about single wire winding advantages.
-More Powerfull Than Same Size Motors
-Tight copper windings
-Reducing wast space
-Much More heat Resistance
-Much faster than ordinary
-Last Long life.
Motor Features,
1. The magnets spec is 40 uh.
2. The bearing is NMB(Japan) ,last long bearings.
3. 0.20mm laminations, maximum efficiency and minimum Eddy Current losses.
4. Flexible motor leads with connectors (220 °silicone rubber.)
5. All motors are Dynamicaly balanced
6. Prop adapters are 5mm. All prop brands can be mounted.
Note: Other size motors will be released soon.
1806-80T -- 17.5gr
2204-100T -- 19.5gr
-Last Long life.
Motor Features,
