Sky-hero Spyder 700 RTF Lightly used. KDE motors Tmotor props zenmuse dji
jjon667
you are looking at an amazing Sky Hero Spyder 700mm x4. This rig is rock solid. The CG is perfect. We have added NEW KDE 2814XF-515 motors and KDEXF-UAS35 ESCs, T-motor 13" props , and a real power distribution board , Zenmuse H3-3D Gimbal. We have also extended the the gimbal mount ahead of the props to keep them out of view. Since we have extended the battery mount as well we have perfected the CG for perfect balance and adjustability. We were using 6s Mah batteries which give a solid 15 20 min flight time. This rig is a work horse. NO crashes. Flight control is a DJI NAZM V2 with GPS. Transmitter is a Futaba T8FG using an S-bus receiver with box. Also included is a Diversity monitor and transmitter. I will tell you up front the canopy has a few issues as it is made from fiberglass. All you need to do is charge your batteries and fly. We have removed one of the white plastic side panels for easy access to the GCU and for added airflow however the part is included if you want to re-install it. This DOES not effect the integrity at all. We will also include extra intertec thumb screws and 1 battery. Also included is a brand new set of extra T-motor carbon fiber props in addition to the the props on the rig its self. This Sky-hero is so well balanced that in attitude mode it will hover as if in GPS. This is a fast reliable powerful multi rotor. We have described every thing to a "tee" There are no returns , no buyer remorse. This rig is RTF. GO PRO NOT included. NO RETURNS ALSO BASED ON NATURE OF HOBBY AND THIS TYPE OF PRODUCT. YOU supply your own charger. Zenmuse will be removed from the frame and packed in its orig box same with the transmitter. Booms can fold back for transport. We will mark the props and booms for quick and proper re- installation of props. All extra parts will be included. 3800.00 You may also call with questions 818 929 9253 or email howard2312@gmail.com
