Secraft s800 arm brace for vibration dampening
chuckwow
Wow they seem to be really expensive.
I have also seen carbon arms that go from arm to arm at the end of the arms. The problem with that solution is that it would require disassembly to remove the arms.
It would be good to hear how these solutions actually work in practice.
maxwelltub
Cheaper then the kopterworx solution. I have seen the carbon option, and although it might seem cheaper, in the end it would probably be more then 177. Also carbon wrapped arms are removable. If you get rid of that feature, the s800 is not worth it.
How would it require dissasembly?, the arms would come off with the brace atatched. it looks like a very good solution
chuckwow
The solution I mentioned are fixed rods (screwed) motor end to end so to remove the arms would require one remove these rods.
I'll see if I can find find the post that shows a picture. It was a European vendor.
