SD card
dewser
I have a striker spy drone my 1st one.My question is when I do a video while flying my drone the 1st video comes out good,but if I stop the video and make another on the same card when I go to watch it it says the card is not formatted correctly.Why would the 1st video work but none after that.Thanks
Drone99
Are you able to see the files on the SD card or it just gives you the error not formatted.
Sent from my SAMSUNG-SM-N920A using Tapatalk
dewser
The 1st video shows up and I can watch that.When I click on the 2nd or 3rd thats when the message comes up
Drone99
That's the issue. When you record multiple ones it writes the same file name. You will need to record one file at a time. I have a hubsan 510s and it does the same thing.
Drone99
I don't think the format would help. It has to do with the chip that's not labeling each file different. If there is a firmware update that might fix it.
Drone99
You could try but if it's your memory card it would not write correctly at all.
