Scratchbuild Copter (Help Please!)
iliketrainz98
Hi!
I only recently got into the rc hobby and what to build a quadcopter.
I enclose my parts list on an excel document, which as links to all the items. You can view that Here.
Alternatively, I have listed them here.
Turnigy D2836/11 750KV Brushless Outrunner Motor
HobbyKing Red Brick 20A ESC
Slow Fly Electric Prop 11X4.7SF (4 pc)
Slow Fly Electric Prop 11x4.7SF RH Rotation
Hobbyking X666 Glass Fiber Quadcopter Frame 666mm
Turnigy Accucel-6 50W 6A Balancer/Charger w/ accessories
Hobbyking KK2.0 Multi-rotor LCD Flight Control Board
Turnigy 2200mAh 3S 25C Lipo Pack
Turnigy 5A (8-26v) SBEC for Lipo
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC)
On Board Lipoly Low Voltage Alarm (2s~6s)
Nylon XT60 Connectors Male/Female (5 pairs) GENUINE
XT60 Harness for 2 Packs in Parallel
Hobby King Quadcopter Power Distribution Board
Prop Saver w/ Band 2mm Shaft (10pcs/bag)
Is there anywhere I can get a canopy?
The spreadsheet is well commented, so please have a look at it and answer some of meh questions.
I have a few points
I want my quadcopter to be stable, so I can put on a filming camera on in the future, plus, I also want to be able to lift heavy payloads incase I want to do thing such as FPV in the future or use raspberry pi's etc.
Also, I am concerned about the motor and the accessories. Do I need adaptors etc that I have missed off, is there anything small I might need (other than heatshrink soldering iron and standard electronics stuff which I can by) That a beginner rc will not have, as well as things I have added that I don't need.
I'd like a long flight time with my setup, around 20-30 minutes: is this possible?
And finally, if any of the products you see can be cheaper, or if they are tacky can you let me know. I don't want to fall into the hobbyking trap of doom where things easily break.
Thanks you very much!! I really appreciate this in advance. I know I have asked absolutely loads, but please do help. I really want to help the RC community to grow - especially to teenagers like me who should want to go outdoors.
Tom
SoCal Blur
In my opinion (which doesn't mean much) First, everyone wants their quadcopter to be stable. The definition of stable that you are referring to, however, seems to mean a good camera platform. Although I think you could get away with a KK2.0/1 FC and a decent camera Gimbal, I think you are really looking for something with GPS so that you can do things like auto level, loiter mode, etc. For that you'll need a different FC. Those features usually come at a much higher price. However, if you're willing to put in a little research and time, you could get those features with a Multiwii Mega Pro3.0 Black board with a GPS option. You can get that for around $80, I believe. But it's not exactly plug-n-play. You'll have to learn some things - which is actually a good thing.
Also, you said you want to lift heavy payloads. How heavy is "heavy"? Usually you need to get into the Hex or Octo copter arena for true heavy lift multicopters. Also, you'll want the redundancy that Hex/Octo provide. You don't want your heavy load falling from the sky if a motor fails. If a motor fails on a Quad, you are done.
Also, Heavy and long flight times are generally not compatible. I think you could manage 20min on a light quad, but it would take some percise building and efficient (read expensive) parts to get 20 - 30 min on a larger, Heavy lift copter. I'm not even sure that it's even practical.
But, as for building your first quad, you're well on your way. Things that you will need are those pesky small metric screws, stand-offs, bullet connectors, silicone wire, etc. that you never think about until you need it and they are not always easy to find locally.
Don't forget a Prop balancer.
