S800 Retractable Landing Gear Problem
sybasurfa
Hi,
Yesterday, After turning on the TX and connecting the battery I lifted the S800 off our prep table to take it to our take-off site. Whilst doing so the tip of the landing gear caught the Landing Gear Switch on the TX that was lying on the table (school boy error noted and now precautions are taken to avoid this!). The landing gear did what it was meant to do and started to raise itself catching me completely off guard. The end result was that the gear lifted up as far as it could until trapping my arm in the last 5% of its journey. I was about to start wriggling my arm to get it out of the way when both sides of the landing gear dropped securely into their initial position (down). Since then we have not been able to use the Landing Gear, I spoke to person we initially trained with who said:
"The gear will indeed go up or down even if on the ground should you flick the switch. It shouldn't cause a drama to the servos or anything unless the gear was trapping your arm for some time- this could stall the servo and in worst cast burn the servo out. However, I doubt very much that the servo has been burnt out. Without seeing the legs and servos I can't really comment on what to do. You should find that the servo will re-set itself next time you turn it on however, be sure that it has the ability to move the legs freely through their complete motion and that there is nothing else that could hinder normal operation."
We have checked and double checked and nothing looks out of place.. there is just no function there when you flick the switch.
Has anyone got any ideas what we can do to resolve this.. I'm hoping its literally a case of re-setting something.. but fear the worst.
Any help will be greatly received. :)
Regards. James
sybasurfa
This was cleared up very quickly DJI Europe.. check LED status.. it was long green flashes.. it needed re-calibrating.
I checked the manual.. followed the steps.. and all is working again :)
Thanks DJI Europe
