If you are just learning then go with the Quad. The lessons are pretty much the same, they will be as easy to fly depending on which flight controller you use but crucially in the beginning, the Quad will be easier to build/repair and cheaper. The one advantage the Hex has over the quad is the potential to fly with one motor dead but this is normally a vary rare occurrence so I would go with the less complex system.
