It is not necessary to remove the red wire from the esc's fir superx as the positive pins on the motor outputs do not go anywhere internally except m7 and m8 which double as gimbal servo control.
IF the red wires are removed would that cause issues? I calibrate my throttle ranges and then when I connect the superX I get the dreaded constant beeping indicating throttle is not low enough.
