Propeller recommendation?
econfly
It really depends on the size and application. For a 15" folder, I like DJI's 1552 prop (S900/S1000) which you can mount to about any motor using an adapter from KDE. T-Motor's carbon fiber props are very well made but expensive. If you are working on a new build check out DJI's propulsion systems. They offer a very good value for motor/ESC/prop combinations and their replacement props are well made and well priced.
It's a tarot 650 sport frame. I can go up to 15". I was thinking of experimenting with different sizes. It will be a small av rig. Zenmuse gimbal with gopro
econfly
Do you have motors and ESCs picked out? In not, the DJI E600 system might be a good choice. Props are 12".
I got a set of castle 35A escs from ebay and was planning on ordering Sunnysky V4010 KV375 motors. I don't want to go with the T-motor props right now as I'll probably break a set or 2 while I'm learning.
