Garret H
Hello,
I'm wondering if someone can help diagnose a problem with a Multiwii SE board I bought from Value Hobby. This is my first time using one of these boards, so I'm wondering if I don't have the settings quite right. Essentially, I am getting a yo-yo effect during flight. The throttle is very sensitive despite a curve and expo dialed in. After take-off, the quad shoots up in the air....then it descends rapidly, then shoots back up. With good throttle management, you can control it slightly, but the flight is not level by any means. I haven't messed with too many of the default settings other than the initial config which I know I did correctly with the help of a friend who uses this board. He has the exact same setup (different radio system) and his is flying fine....he initially reported the same problem, but changed RXs and the issue went away. I did the same but the problem persists.
Any help would be appreciated.
Thanks,
Garret
Thanks,
Garret
