SixPropYaw
This video shows a DJI S800 with A2 controller being powered up from cold via a Jeti DC-16 Tx. The Jeti switch used has a 200 Amp rating and includes voltage and Amp monitoring. The contactless switch is controlled by a Jeti RC switch. The radio is dual band (Double-Path) - each RSAT (set to 15 Channel) receiver communicates with the Tx via its own reserved portion of the 2.4Ghz spectrum. Disconnect an Rx and no control is lost. This system was used to film the BBC Live HD coverage of the London New Year Fireworks 2014/15 (Main contractor: Extreme Facilities Ltd, Clapham). A parachute system linked to the main power switch (with delay) provided an 'abort mission' solution. Control Configuration, pre-mission testing: AeRobot Ltd.
